Here's what I'm currently planning for my blade to use with a 10 Watt greenie from LedEngin.....
I have a thin wall 1 inch outer tube.
I also have a smaller thick walled 3/4 tube.
A tip from clear resin that fits inside the 3/4 tube then steps up to fit inside the 1 inch tube.
My current plan is to sand the inside of the 1" tube, and both the inside and outside of the 3/4 inch tube. Then I read about the cellophane with the Corbin film... which I presume would also work with what I'm doing.
First... are two tubes really neccesary? Will it help any? I could always just use the single tube.
My current thought is to sand the inside of the outer tube, fill it with Cello then install the inner tube, sanded inside and out.... then maybe toss some cellophane inside the 3/4 tube? Overkill? Maybe even entirely fill (or almost) the gap between tubes with cello?
It's kind of new territory with the 10 watt LED, but since I'm using a couple buckpucks to drive it there won't be any extension/retraction anyway. General thoughts of more experienced folks.... more lumens means more diffusion needed?
