Originally Posted by
Mineral
1) Tighten it all the way down and mark a reference point across the join.
2) On the threads of both the male and female ends, use a sharpie (or whatever) to divide the circle into quarters. Use your reference mark to make sure the quarters line up on male and female ends.
3) Mark the corresponding quarters on male and female A,B,C, & D. So when it is threaded together, male A touches female A and so on. (you can actually do all this marking on the outside of the saber)
4) Grind off the threads, male and female, of A and C, with a tiny encroachment into B and D on both ends.
Now you should be able to slide the two parts together and give it just a quarter turn to tighten it. Using this same idea you could divide it into sixths and only need a one-third turn, or whatever.
