can anyone help me with the resistors? I tried using the calculator but I couldn't figure it out
Just curious, did you check out the post I linked you to? It lays out the equation and also gives a link to FJKs helpful tut.
Here it is within your thread:
(Supply Voltage - LED Vf)/Amps
**I do not know if these are your numbers. Just examples.
So for instance, if your battery is 3.7v, and your LED has Vf of 2.5 and you're driving it at 1A you would do this...
(3.7 - 2.5)/1 = 1.2ohms (numbers in red are the ones you use in the online calculators)
Now for the wattage you need take your resistance and multiply it by the current squared...
1.2*(1^2) = 1.2w or 2w rounded up (or greater)
FJK has a better explanation here http://forums.thecustomsabershop.com...e-to-Ohm-s-Law
