Hey there everyone,
I'm working on my first build, and I'm using an Arduino.
I want to use a Cree RGB High Powered LED, but I have some questions.
First, is there a way to run the LEDs in series and still be able to mix the colors (dim them independently, using pwm)? I'm afraid that running them in parallel would drain the battery way to fast because it pretty much triples the amount of current being drawn. Or, is there a way to run them in parallel and still have a decent battery life? If I do parallel, I would use some buckpucks I found that let me use pwm logic to dim the leds, as well as a 5v output that I can use to power the arduino. Is there a better way?
Also, the leds are rated to run at 1000mAh max. Is it bad to puch them all the way to the max, or is that the only way to get them to their maximum brightness? I ask because if I ran them at a lower current I could save battery life.
Thanks.
