Originally Posted by
Silver Serpent
FJK's numbers are good. If you'd like to know how he got them, it's actually fairly simple.
Add up the mA of all your individual LEDs. Typically 1000mA for each of the Tri-Cree dice. If you're doing color blending, you're usually only using two at a time. The AV switch LEDs are usually around 20mA each. Then throw in about 350mA for the sound board itself. That gives you 2390mA for the whole saber.
Take the mAh of the battery pack and divide by 2390, and you'll get the estimated runtime in hours.
