Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Petit crouton, Tri Cree, color mixing and ext HELP
    Default Petit crouton, Tri Cree, color mixing and ext HELP
    okay, so i am new to building a saber. i am planning on building my first one some time in the next month or so. now ive already figured out all the MHS pieces i need, as well as shrouds, and custom machining. what i need to know now, is in reference to the internals. I am planning on using a petit crouton v3.5 and a custom tri cree led. The colors will be blue and green to create arctic blue, and then white for FOC. now, how do i wire this, in order to adjust the led's? do i wire the blue and green together and solder them onto the main led port of the PC? i want to be able to use RICE to adjust the brightness of each of those 2 led's in order to achieve the exact arctic blue color i want. Do i need a power extender for this feature, or can i just wire it straight to the PC, and its good to go and adjust from the start? Also, when wiring in the white led for FOC, will the white led be on the whole time? mixing with the other two, and then the blue and green flicker for FOC?, or is the white off all the time, and then flashes for FOC. IF so, does the blue and green shut off and the white flashes, or does the blue and green stay on and the white flashes with them for FOC?
    when wiring in a momentary switch for the blade lock up and blaster sounds, do i just wire it in to the secondary button port, and then the PC is pre programmed to set that control to any button wired to that port, or would i need to use RICE to set that button to control those functions?
    Youngling Zahc Zi Phan's Avatar
    Aug 2012
    The forest moon of Endor
    201
    I will try to help a little here. Keep in mind I am no master. Hopefully FJK or Jay-Gon or someone else will chime in too.
    You can wire that two ways. Option one is in series, so positive lead from board, first LED, wire the negative of first to positive of second, and negative of second returns to the board. In series you would set the board to run at 1,000ma which would be sufficient for both dice, the voltage would double, so you would need a 7.4v battery.
    Option two is series so you wore both dice up individually and attach them both to the same pads on the board or split the same positives and negatives to make a Y and go to both dice. You would have to run the main channel (split between two dice) at 2,000ma.
    With either option wired like that, you can not adjust the color through RICE. You can only turn the current up or down and hope you like what you get. More experienced builders can use resistors to achieve the right colors, but I don't know a thing about that. Not my ballgame.
    If you want FOC, you need a power extender at the least. A color extender would be optimal, and would allow you to mix the colors and get the best ice blue. With plecter boards and RICE, you can configure the FOC to be standalone or on top of main color so the other colors do not turn off. If you go RGB (which is the BEST OPTION) you can have the capability to run FULL color mixing, and can define exactly what color you want FOC to be as well.
    There is a main switch and an aux switch on the PC 3.5. The Aux is automatically set to function as the blade lock up and blaster effects. You do not need to turn this function on or mess with it, but it all can be customized.
    So in my opinion, for the best results possible, get a RGB Cree, a color extender, do some homework, and wire that bad boy up. You will not be disappointed.
    i was thinking of doing an rgb. so since mixing red, blue and green make white, i would then wire my red led to the foc terminals? as blue and green would be on to make the arctic blue, and then the red would activate to create white? OR would i wire all of them as the main led, and then could control foc from there? or is foc only controlable through the foc terminals on the PC3.5?
    what is "plecter boards"?
    will wiring in series allow me to control each individual led with this plecter board thingy? or would they have to be wired seperately through a color extender, and then the purpose of a color extender is to individually identify and control each of the led's, and transfer this data back to the petit crouton?
    sorry but like i said i am new to electrical, and computer chips. i only know software, not hardware.
    Welcome to the Forums.
    I strongly recommend that you download the P.C. Manual from the store, and read it over a few times. It should answer most of your questions.
    Plecter Labs is the manufacturer for the boards that are sold here in the store.
    okay, so. the fact that plecter boards makes the pc3.5, clears up a bit on color choice and wiring and such. ill just wire the blue and green as main, and the red as foc, and have it run on top of the others to make white. the only thing now, that i cant will not be on the pc manual, is which led is brighter? i know there are probably arguments everywhere. but as a moderator, and having seen and most likely experienced this yourself. out of the rgb led's sold here specifically, which would you say is brightest? and what wattage are they? it doesnt say in the led description. are they 5, 6, 10, or 12?
    Quote Originally Posted by Ambrosius Malachai View Post
    The Tri-Cree RGrB would be the brightest. "Wattage" is just a measurement and not a real indication of how "bright" a LED is - essentially its kind of a marketing gimmick.
    RGrB, is that red green royal blue? is the royal blue brighter than regular blue? or can i just do a regular blue on a custom tri cree. thanks for the info by the way
    My hunch is that you would prefer rB to regular blue anyways if you're trying to get "arctic" blue, but yes, RGrB is red green royal blue. And yes, you can do a custom with a regular blue but it's going to be more expensive and again, I think you'll be happy with the RGrB. But of course, it's your saber and I'm not trying to tell you what you like, it's just my opinion.
    Also, Zahc, you listed the 2 wiring descriptions as series and series. And PC V3.5s have on board power extenders so you don't need to buy one.
    ERUDITION
    if they have the power extender, then how do i wire the 3 led's? do i wire the blue and green as one in series to the main port and the chip can figure it out, or do they go to two seperate ports, and then the red to foc? because if in the future i want to change the color, if foc is the red, will i be able to adjust it in the constant regular use, or will it only light on foc?
    Aug 2012
    201
    Ahh yes. Poo. I mean option one is series and option two is PARALLEL. Of course you knew that Miraluka. Lol.
    Yes Plecter Labs is the manufacturer. Great stuff.
    If you wire the color extender like the manual says, you don't need to designate a single die for FOC. It's all built in and fancy like that.
    I believe you can also skip the color extender and achieve rough "psuedo" color mixing using a single cell 3.7v hack with the PC 3.5. I have not done this so I cannot speak for it.
    I also did not know that the PC now had an on board PEx. Good to know!
    Step one OP is to download the manual from plecter and read it, it is very in depth and will guide you in the right direction. The sky is the limit with these things, within reason of course. That's why it's such a fun hobby.
