Results 1 to 10 of 14
Thread: First Saber; very comfortable with soldering and electronics
    Default First Saber; very comfortable with soldering and electronics
    Here is my part list of what I am planning on ordering:
    Updated:
    Outter Design:
    MHSV1 Blade Holder Style 19 w/ MHS Heat Sink V4 (Flat Style)
    Activation box style 19
    MHS deep ribbed extension
    MPS Pommel style 4
    4" Deep fluted
    4" Double female
    Double ended male threaded connector style 1
    MPS Pommel style 4
    Kill plug style 2
    MPS Insert style 6
    Inner Design:
    Chassis Disc style 5 x2
    MHS speaker mount V4 - For 28mm Speakers
    Acrylic Chassis Disc for PC 2.0 and 18500/18650 pack - S2 (Black) x4
    1/2" Aluminum 3/16" OD spacer (Black) x6
    1" Aluminum 3/16" OD spacer (Black) x6
    2" Aluminum 3/16" OD spacer (Clear) x6
    3/4" Aluminum 3/16" OD spacer (Black) x6
    Brass 4-40 Hex nut x10
    Stainless 4-40 all thread x2
    Switches:
    Black momentary switch
    Switchcraft 2.1mm Power Jack
    3.5mm R.I.C.E.? Port Style 2
    16mm Anti Vandal Short Momentary Red Ring Switch
    Electronics:
    7.4v Li-ion 1600mAh 14500 Battery Pack
    Premium 28mm Speaker
    Petit Crouton V3 Color Xtender
    Petit Crouton V3.5
    270ohm 1/4w resistor
    LED:
    Red/Green/Royal Blue Cree XP-E2 CopperNova
    18deg Tri-Rebel/Cree Star Lens
    Star thermal tape pad
    Misc:
    3.7V-14.8V Li-Ion Smart charger
    Super Lube Synthetic Grease
    USB to 3.5mm R.I.C.E.? cable
    8-32 x 3/8" Stainless Steel thumb screw; blade retention screw
    8-32 x 1/4" socket head
    Box 19 Mounting holes service
    Drill & Tap Hole (8-32) for retention screw
    Drill & Tap Hole (8-32) for covertec button
    Lots of wire and heatshrink
    MHS Builder:
    So, do you all think I got everything for now?
    I do have a question though. For the 16mm Anti Vandal Short Momentary Red Ring Switch, a: Will it fit within box 19 and b: do I need to wire a resistor to the lighting portion of the switch (I'm a little confused about it), or will the Petit Crouton take care of that?
    Thanks!
    Welcome to the Forums.
    To answer your questions:
    Yes the switch will fit, though you will need a resistor for it.
    You appear to have almost everything you need, however, I don't see a pommel insert or a c-clip to hold it in place. I also think that you don't have enough chassis parts for what you want to do. You'll need more disks and rods.
    Design wise, I also highly doubt your battery solution will fit in the hilt as it is currently designed.
    I looked at it again. I assume that the chassis will be in the way of the switches?
    Quote Originally Posted by Alriightyman View Post
    Not the chassis so much as the battery itself. The switch and ports will extend about halfway into the hilt interior, leaving about that same amount of room, perhaps slightly less, for the battery to sit in. The concern is that your switch plate won't screw down properly because there won't be enough room for it.
    Even with that smaller battery pack, I'm not sure you'd have room for your speaker. Hard for me to say.
    ERUDITION
    Well, I guess I'll have to redesign another one. Not sure what to do now though.
    Thanks anyway.
    Or you could just use a single 18650. That should fit the space just fine and leave a bit of room for resonance.
    ERUDITION
    Well, I am stupid. I didn't realize that I had selected a double. I thought I had a single. Thanks for pointing that out.
    May 2015
    United States
    1,756
    2
    You'll need to hack the board to work on a single cell. Or you can switch to a Prizim. Make sure to read up on the manuals.
