Ok, Step one i ordered a hilt, A bane from saberforge.
Now, i would like to rig it up with a momentary switch (blue) a Tri Cree, which i have some questions about, and rig up a recharge port and an Aux button which will be used at latter time. For the moment Aux is just pluging a hole.
Now my questions:
on the Tri Cree I want to order a custom where all three are Royal Blue, After looking at the newbie section, I've determined that the Voltage @ 1A or 1000mA is 3.41v. were i to hook them in series the voltage is 10.23v. I obviously cant run that from a 7.4 battery. So is this where this item comes in? http://www.thecustomsabershop.com/Co...iver-P609.aspx
also using this would i still need resistors in place?
And which 7.4 battery module to i need to get?
So to finish out what else im shopping for:
http://www.thecustomsabershop.com/He...ole-P1011.aspx
http://www.thecustomsabershop.com/MW...Port-P877.aspx not running to a buck puck
http://www.thecustomsabershop.com/12...itch-P925.aspx ok on this item, if a momentary is not applicable would i need to get the converter to make it possible?
http://www.thecustomsabershop.com/Ki...le-2-P570.aspx and would this actually work as a kill key in this configuration? If not , how would it need to be rigged?
http://www.thecustomsabershop.com/18...Lens-P778.aspx
and http://www.thecustomsabershop.com/Cu...LED-P1035.aspx with all three in royal blue? unless that is gonna be far to dark... Is there some where to look at the color samples?
And could someone point me towards the right 7.4v module? ANd i do want to get a charger so that i can just hook up a cable and charge the saber with out ripping it apart.
Im sorry for being a pest, But i could really use some help here.
