Jedi Padawan
I think my PC 3.5 is not right
So I just finished getting my LED set up to connect to my new SB. I'm using a tri-cree RRW. When I turn on the saber the only LED to come on is the White die. As well when I hit the button for the FOC that same white die flashes.
I've been down my own list on this, mainly looking at the way the led is wired. I even looked at the SD card for an answer. So I formatted it and put a copy of the same info from a different SD card and nada, nothing.
So....any suggestions?
Check the override configuration files.
Yes, comment out the color profiles in the override file.
Jedi Padawan
Please post your override file. It is almost certainly the color profiles as mentioned above.
Jedi Padawan
Here's my override file
## Override File
vol=4
beep=40
valsnd=1
switch=2
offp=0
offd=200
lc=400
hs=200
ls=67
i=55
swing=200
clash=150
lockup=150
## Color profiles
color0=0,740,0
fcolor0=740,230,0
color1=0,0,740
fcolor1=700,0,740
color2=740,0,0
fcolor2=0,430,200
color3=0,630,200
fcolor3=500,740,0
color4=640,0,430
fcolor4=0,0,740
color5=740,230,0
fcolor5=0,740,0
color6=540,730,0
fcolor6=0,740,400
I've gone through and disconnected and reconnected my wiring. NOW the FOC and main are back wards. That is to say that the FOC are the two RED dice, and the MAIN is the white die.
As stated before, the problem is the color profiles. If you delete all the lines in the override file below the "##color profiles" line, then the led currents will be defined using the LED parameters in the config files like you're expecting them to be.
Jedi Padawan
Okay so here it is, I did delete all the lines below the "## color profiles" now my two red dice for the LED (main) are up and running. The white die however for the FOC is not.
Are your wires still backwards? Could you also post the config file of the bank you are using now that you have deleted the color profiles from your override file?
Jedi Padawan
no not backwards any more. The two Red LED's I have wired in series (RRW, white for FOC) are working fine, and ridiculous bright. The white LED is the one that is not working when the clash, blaster, lockup button is pushed. Here is a look at my current override file
## Override File
vol=4
beep=40
valsnd=1
switch=2
offp=0
offd=200
lc=400
hs=200
ls=67
i=55
swing=200
clash=150
lockup=150
## Color profiles
I think what I need to do is put in the first two lines after the "##color profiles" line for the FOC die to work.
