This is the first saberstaff that I've built. Because it's a double bladed saber, I figured that I would need to frequently shift and change grip on the hilt while swinging an spinning it so I've decided to keep it as sleek as possible. The result is a pretty simple MHS based design. The inside of the saber was somewhat more challenging as I've never done a setup like this before and to include all the features that I wanted, some major cram-fu was required. This is also the first time I've used custom 3D printed parts for the crystal-chamber and the internal chassis. I'm sure I'm going to use them again as they made my life much easier.
As always I have to thank Tim for the great custom work he did on the MHS parts that I ordered.
Specs (for each saber):
- NanoBiscotte v2.0 with PeX for FoC
- Tri-Cree Xpe2 RRW LED
- 2W speaker
- 3.7V 3400mAh li-ion battery
- Illumintated crystal chamber
- Illuminated red ring 12mm AV switch
- 10 segment Power Level Indicator
Video
