Switch led luxeon led and question
for use this
16mm Anti Vandal Momentary Switch Blue Ring
or this
16mm Anti Vandal Short Blue Ring Momentary Switch
i use http://led.linear1.org/1led.wiz
for calculate resistor for led inside switch, he show me 39 ohms , 1/8w, i dont find it in store, where i can find it ?
and about Luxeon Rebel Star (Royal Blue) i need one 1ohm, 2w
is bad if i use 2.2ohm 5w resistor, or i need the corret?
You can use the 82 Ohm 1/4 W resistor for the accent LED, and the .47 Ohm, .5W is the best one for the Blue main LED.
