Hi all,
I've wired up my PCv3 with CeX for testing to make sure everything works before I try to wire it in a chassiable way. I've used the diagram I made and verified here: http://forums.thecustomsabershop.com...Ex-and-R-I-C-E
The only issue I'm having seems to be with the color extender. I have the banks set up so that bank 1 is only blue, bank 2 is only green, and bank 3 is only red. There are only issues when I'm in bank 2 and 3. I've tried each LED on channel 1 using bank 1 to confirm the LEDs work, but it seems that channels 2 & 3 are sporadic at best. Sometimes the LED is on, sometimes it's not. Some times another LED is on too. Not sure what's going on, but I have also verified that the control signal is being sent to each channel on the CeX when it should, so the problem is either with my wiring or with the board itself, it would seem. Anybody see anything wrong here?
The picture of the CeX in the store doesn't have to two cylinders sitting staggered like they are on my board. Could that cause issues?
