My plan is to start by building a simple(ish) saber and slowly add more features to it as I have the time and money. The ultimate goal is to have a saber with a PC soundboard and color extender with an RGB LED so I can control the color. With the end goal in mind, I want to put an RGB LED in this saber from the start. I'm planning on driving the LED with a 1000ma buckpuck, and wiring the green and red dice to make a yellow blade for now. I've heard the tri-rebels don't mix very well (at least the RGB) and I'm wondering if I can use this LED star I liberated from a saber I have from the other guys. I don't really see a problem here, but wanted to check with you guys before I committed to using this LED.
Will this work? Any suggestions for a different RGB LED I could use?
