does the 2AA holder have a special compartment for the sound card? Cause they look like the 4AAA
Not specifically, BUT if you look at the pictures in this speaker/battery holder combo, you can get an idea on how to mount the card using 3M double sided tape. http://www.thecustomsabershop.com/MH...kers-P358.aspx
The AA batteries also have almost the same mAh than the AAA. AAA seems to have 1000mAh. How would AA make last longer?
Also, what's the max current and voltage ofvthevblue leds ibchoae, so I can calculate the resistance
Current and forward voltage requirements for the Rebel LEDs are listed on the store page: http://www.thecustomsabershop.com/Lu...Star-P523.aspx
They say two voltages, should I use the "run at" in my calculations? And what about my batteries question?
Thanks
Ok.
Would one AA battery runs longer than 4AAA? I mean, they all have like the same mAh, so shouldn't they last equal?
Searching online on brazilian stores I found 4xAAA 1.2V AND 1000mAh and 4Aaa 1.2V 3000mAh. I think to last longer the best option would be 4xAA. I can buy a 4xaa holder and the speaker separately. What you think?
