I am thinking about making a light saber for my girlfriends daughter. She is indeed a girlie-girl and I am planning on making the hilt pink. Does anyone know if it is possible to make pink LED as well?
Yes, Red and Blue (possibly a resistor on the blue) will give you a pink color. You can also get a RRW and use the Red and White to make a pink color. Eastern57 just did one with the RRW pink blade if you'd like to look at it. See the Fluttershy saber in this thread: http://forums.thecustomsabershop.com...ed-lightsabers
Thanks for the reply to the both of you.
How do you adjust the color using a PC? What about buying a Luxeon Tri-rebel star with royal blue, green & red and mix the red and blue?
I got a wonderful pink by mixing a Red and White from a Tri-Rebel RRW. I don't remember my settings but if you resistor the white (it will otherwise overpower the red and you won't see much more beyond the white itself), you'll get a good looking pink.
Unless you plan to use a PC3 (and RICE) which is overkill on this project because your building a FULL color changer just to get pink.. I would just use the RRW (and resistor method).
In this way you can still get a terrific pink without the technical overkill of a full color changer build. To tune it lighter or deeper pink just adjust your resistor values slightly.
Or wire in a potentiometer.. (That's how we used to do old school purple or even the silverish blue's) Use the pot to set your color.. Measure across the pot and replace with that resistor.. (Make any colors you like!) easy peasy.. And fun!
I hope this helps.. Keep us posted on your progress!
Ah, silly me
Do you guys know what resistor I need? Perhaps a silly questions but what is PC3 and RICE?
Yesterday I got the last parts I need to build a Visas Marr light saber for my gf so the light saber with pink blade is probably not going to be build before late summer at the earliest I guess. I will keep you updated on the process.
PC3 is the Petit Crouton v3 soundboard sold in the store here. RICE is a method of connecting the soundboard to your computer so that you can adjust settings in real time (colors, blade flicker, etc.)
If you don't wish to use that method, then get a potentiometer (adjustable resistor) and put it on the LED die you wish to adjust, find a setting you like, then measure the resistance of the potentiometer. Replace the pot with a resistor of that value. You will need a multimeter to do this.
I asume PC3 is the same as the emerald drive that US sels, right? I have seen a video of what that can do and it is tempting to buy one but as mentioned it might be somewhat overkill for a kid. I am going to look up the potentiometer.
