JSTs are nice, but if you use too many, they'll eat up hilt space faster than you'd think. Trust me, I've already gone down that road.
For multiple wires, just strip some of the insulation off, twist them together as best you can, and then solder. Don't forget heatshrink over the joint. If you have a set of helping hands, then those will help tremendously.
Ok so I trying to redo my board but one of the problem is my cheap soldering iron, it's a 6 dollar soldering iron and I already bought two new tips for it and it just doesn't transfer heat, given that I do use a web sponge and I really try to wipe and clean the tip as much as I can, when I place a copper wire over a old solder to remove and place my iron I have to wait for several minutes and after that nothing, I know it's hot but nothing happens, when the tip was new it worked fine but after few solder removal it craps out,
I think I need a better solder iron any suggestions with budget in mind??
Did you tin the new tips before using them? Also, consider swapping to one of the brass sponge tip cleaners. They don't steal heat as quickly, and clean the tip better.
A dirty, untinned soldering iron tip doesn't transfer heat properly, and will give you issues, regardless of the quality of your iron. That being said, I prefer to use Weller brand irons. I hear good things about Hakko as well. Similar quality to Weller, but generally less expensive. The cheap Radio Shack irons are good for stained glass projects, but I won't use them on delicate saber parts anymore.
Ok I'm stupid what's tinning the tip? I thought tinning was for the wires. Do you mean I use solder on the tip of my soldering iron? Not sure
Yes, on a brand new soldering iron tip, you will want to coat it with solder prior to use. I always wrap the cold tip with fine gauge solder, then heat it up until the solder melts. Wipe off the excess solder onto your sponge or brass pad. The tip of your iron should always be bright and shiny. If the tip is dull, you need to clean it.
When you're finished using your iron for the day, clean the tip, and reapply a little solder again. This will help protect the tip from oxidation and make it last longer.
Well I guess it's safe to say I ruind yet another tip unless I can still tin the tip? I doubt it. Either that or off I go to buy another soldering iron, dang this saber project is getting expensive fast
When I first got stated, I used a cheap soldering iron. It was a pos, but I built quite a few sabers with it and learned a lot with it. Then I tossed it in favor of a soldering station when I started working with quality soundboards like the PC. Personally, I've got a Weller WES51 and a couple extra tips - a fine point for making the connections to the small pads on the board, and a fat tip for general use - but there are a plethora of choices. If you plan on building more than 1 saber, I'd recommend making the investment in a good piece of equipment. Just my two cents.
