Hi,
Can someone please check my parts list for me prior to me submitting my order. I also have one quick resistor question (at end of post) if someone can help with that too please. Thanks.
HILT
Pommel style 3 version 2
4 inch double female extension
V- grooved ribbed extension + powder coat black matte Tuscan style 2
Blade holder style 16 + powder coat black matte Tuscan style 1
(with new style heatsink)
Pommel insert style 6
MPS “C” clip
Screw – blade holder 8-32 3/8” thumb screw and 8-32 3/8” set screw (I want two options)
Switch – AV blue ring LED short
Recharge – 2.1 jack port
Kill switch style 2
SERVICES
Drill and tap blade holder
Recessed AV switch hole (in V- groove)
ELECTRONICS
Li-ion 3.7 V rechargeable with PCM (local supplier TCSS don’t send overseas)
Nano Biscotte sound module
Premium speaker
LED – rebel star royal blue/lens holder/thermal tape/8.7 degree lens
LED – resistor 1 ohm 2W
Switch – resistor 20 mA Dyna Ohm variable
Wire 1 foot in red and black (24 gauge)
Heat shrink 1/8”
2 x quick connectors
CHASSIS
1 foot thread rail
1 foot aluminium tube
Acrylic discs 18650/NB
Metallic disc style 2
2 x 4-40 hex nuts
OTHER
Blade 1” TCSS battle blade 36”
Blade plug
Synthetic grease
Smart charger +2.1 plug adapter
WIRING DIAGRAM – I am going to “borrow” the wiring diagram (attached) I found on the forums that someone did an awesome job on already. I was just going to remove the accent LED from the plan however. I had one quick question about it though. I noticed he is using a 82ohm 1/4w resistor for the AV led switch. I worked out I only need a 1 ohm 1/8w resistor but was going to use the 20mA Dynaohm. Why has he used the 82 Ohm resistor, did I miss something ? Is this because of the recharge port set up. This is the only thing left I am confused about before doing my order.
Thanks Luke
