http://en.wikipedia.org/wiki/Ohm's_law wut?
I'm not a cartographer but if given a map, I can drive myself to my destination.
Is there a wiring guide for the set up I want? Surely what I am doing is not the first of its kind. I don't know what fwd voltage is or if amperage and mah is the same or different. I would need to take an electronics course to understand all this stuff.
I looked at the resistor calculator in your signature too. What I am not sure about is how do I include the nano board in the resistor set up? I have lurked for a while around here, signed up, then lurked more. I just don't get it. I don't understand.
Red which is 3v 800mAh
Those are MAX values. We do calculations off of "typical" values.... So I will give you the values to feed into SS's little calculator, especially where LED voltages are concerned.
battery back =3.7v
red led = 2.3v
current = 800 mAh which is what the max the led can take and probably what the battery can dish out.
"The wizard recommends a 2W or greater 1.8 ohm resistor. The color code for 1.8 ohms is brown grey gold."
Ok so how does the sound card play into this?
Ok so the sound module pretty much manages it's own power from the battery and the power goes from the battery directly to the led through the resistor?
That would be correct.
Well, the power goes from the battery through the sound board, then through the resistor and into the LED. But yes, the sound board manages its own power, provided you use an appropriate battery pack.
