Results 1 to 10 of 11
Thread: Illuminated AV for a NB
    Default Illuminated AV for a NB
    I have been looking on the forums for a bit and I am still baffled on how to wire an Illuminated AV switch to a NB I am sure its easy but I have absolutely no electronic experience what so ever. If there is a post some where that I have missed please point me in the right direction. I just don't see how to wire the switch LED to the rest of the circuit, pictures on how anyone soldered their NB sabers would greatly help. I am using the MWS Nano B with all JST connectors.
    I have all resistors and other stuff figured out so just this one part is confusing me/
    Hi Captain,
    Take a look at page 10 of the owner manual, you'll see where to solder AV Switch Led (3.3v accent led pad). That would require a recherche port with kill key tho, otherwise the led will stay on and use battery unecessarily.
    I've also read you could wire this led in parallel of the main blade led, if you do not want to use a recharge port (that way the accent led only ignite when you start the saber). this is actually easier to wire if you have JST (just put both led wires t your JST male plug, with the proper resistor of course).
    Hope it helps
    Clicky Sig =>
    Alas but I am using the NB MWS with all the JST connectors. So would I connect the Accent LED neg to one of the per-existing wires for the battery?
    Quote Originally Posted by Captain View Post
    It would have to be connected to the battery (-).
    Well, that is a problem. If you wanted to have the accent LED illuminate only when the main LED is on, you could maybe use one of these to wire the accent in parallel with the main. IOW, use the same + and - that the main LED is using, just make sure it goes through its own resistor and not the main LED's one.
    The other route is of course to solder a connector to the 3.3V pad in the middle of the sound card.
    I plan on using a kill key with a charge port. So would I want to solder the switch LED positive to the accent LED pad and the neg to the battery neg then. If so do I cut the battery neg and solder the switch LED to it then heat shrink it, so it would be three wires getting soldered?
    That probably would be safest.
    Your accent LED circuit should run from the 3.3V accent LED pad to your resistor+LED and then back to the negative pad on the NB itself (which is the negative node that comes back from the recharge port), not the negative terminal to the battery itself. The negative terminal on the battery runs to the recharge port and nowhere else.
    Alright thanks Xevious. Good thing I came back and checked!
    Quote Originally Posted by Xevious View Post
    i have also wondered this. so if i read your post correctly i would wire the - from the swich to the same prong of that the - wire goes to on the recharge port. just like the battery and board + prong?
    ABANDON ALL HOPE, YE WHO ENTER HERE!
    Canto III of Dante's Inferno
    Beware the Power of The Pope!
