Well, I may take a break half way through this and return later. But, here is what I want to discus; the LED Engin LZ4.
Last night I just worked on my first LED Engin LZ4. I had the wiring planned out, and had my diagram on the screen for reference. I've wired up about ten Luxeons (still new too sabering), so I feared not the actual soldering part. I got my station heated up, got my wires tinned and was ready to tin the pads on the Engin.
-side note: prior to this I had read that the Engin's were tough to solder, so I was prepared for a little trouble.
So, I heated the pad and had a little trouble putting down some solder, but eventually got it. Some I had more problems with then others, but no biggy. Now it was time to add the wiring, which was a little tricky because the two greens (on the RGGB) are on opposite sides of the die. But I got the wiring on and all was looking good. IT WAS NOT.
-Side note 2: by the time of my writing this I have gotten it to work, thanks to some tips posted on the forum.
Just when I think I'm done, one or my wires pops of when I was moving the led, then another, and another and . . .
The next hour or so is a battle between me and LED, I would solder wires down, and they would come free. I cleaned and retinned and cut and stripped wire, but no avail. Alas, I was going to undo it all and try again today, however, there was one wire I could not pull free. I even tried pulling it free with pliers, but feared damaging the LED pad itself, for this one wire would refuse to move.
This in fact gave me hope. If this one could stick so well that it would not be removed with force, then surly the others could do the same?
So to the forums (and Google) I went. That is when I found this discussion. Which is one I had read in the past but had not bookmarked. The info here helped me to succeed.
To the point of this long and drawn out story.
I wanted to start a tread on the best practice methods of soldering blade LEDs (or soldering in general).
Here are some of my points, most learned from others and proven through personal experience. Some, are idea's I'd like to have noted for next time.
1-Heat, heat, heat: The biggest problem with wiring the Engin was (for me) not having enough heat. I needed to heat the pad much more then I was. To get things to work, I would leave my iron tip on the pad for 15 or so seconds, then put some solder down. After that I'd addthe wire and maybe some more solder from the tip (if there was room).
2-Positioning: Using Helping Hands, or having some way to position the Led where you can work with it easy and change the angle when needed makes things much easier. Especially when you have to jumper pads that are on opposite sides of the die.
3-Heat shrink: One of my biggest problems was my design Ideals. I'm wiring my Led to a four wire quick connector. So I had to run the wires through the heat sink and then to the Led. WRONG! This made it hard to get good positioning (see point #2). What I should have done was use thinner wire and just solder them to the Led pads, then run those wires through the heat sink, after everything was tested good. Then I could have solder those wires to a quick connector and just used a few inches, from the hundreds of feet of heat shrink I have, to cover them.
Any way, I've got it wired and working now. I'm still tempted to buy another one and just start over fresh just to have done right from the start. Maybe later.
Please add any point/tip/trick/techniques you use. Or feel free to correct/expand the one's I mentioned above.
Happy Sabering,
The Yin
