hey. you'll need to use a power extender http://www.thecustomsabershop.com/Po...r-20-P652.aspx to bring the voltage of the 3.3v pad to 7.4v then resistor from there. also, be sure your pc 1.5 is set to run foc. i have a couple older pc 1.5's that were flashed to unlock them but they weren't flashed for foc. it think that started with version 1.6.
check your config file. if you see any auxflashXX parameters then you're good to go.
hope that helps.
