Ok so this is what i have for my up and coming lightsaber build, i have found many diagrams for the PC and wiring it up but some things still leave me guessing, like the led it is a amber led by rebel star, what resistor should i use. well here is my parts list with the extras added.
Screw on LED blade holder style 13
MHS "new style" Heat Sink
Pommel style 3
Blade Holder Powder Coating (Copper Metallic) (B132)
Pommel Powder Coating (Copper Metallic) (PO31)
Rebel Star LED & MHS Heatsink Module
Luxeon Rebel Star (Amber)
16mm Anti Vandal Latching Amber Ring Switch
82ohm 1/8 watt (av switch ) -Correction
Black momentary switch
Activation box style 2
2.1mm Power Jack
Kill plug style 4
Wires and heat shrink
Petit Crouton Sound Module V2.0
Light Meat
7.4v Li-ion 1400mAh 18500 Battery Pack
3.7V-14.8V Li-Ion Smart charger
2.1mm plug adapter for smart charger
MHS speaker mount V2
Premium Speaker
Drill & Tap Hole (8-32)
location: on blade holder 9 place the hole somewhere between the cut outs or if you think below then do that, use your best judgment.
location: On Blade holder style 13 place the hole in the middle, use your best judgment on this.
MPS Clip
MPS insert style 12
JST connectors
Super Lube Synthetic Grease
8-32 x 1/2" thumb screw
8-32 x 3/8" Brass button head screw
8-32 x 1/2" button head screw
8-32 x 3/8" Stainless Steel thumb screw
(im ordering a few different screws to find what one i like)
D-ring belt mount
1" Hilt safety plug (Trans White)
Acrylic Chassis Disc for PC 2.0 and 18500/18650 pack (Clear)
4" Deep fluted double female threaded connector
Double male with slots
Extension Powder Coating (Copper Metallic) (DME2)
MPS Pommel style 8
Screw on LED blade holder style 9
(im getting an extra pommel and BH so that i can switch around the parts when i feel for it)
Pommel Powder Coating (Copper Metallic) (PM81)
Blade Holder Powder Coating (Copper Metallic) (BH91)
4" Double female threaded connector
Box 2,3,5,6 Mounting holes service
location: in the middle of the 4 inch double female threaded connector. this item will be media blasted as well
Media blasting
Media blasting: [1. Gray areas only (This item will also be getting a powder coating style 1) Screw on LED blade holder style 13 - Im guessing you'd media blast then powder coat .] [2. Activation box style (2)] [3. 4" Double female threaded connector] [4. 4" Deep fluted double female threaded connector] [5. mps insert style 12]
(No resistor needed for Amber led)- fix
Well this is a HUGE parts list if anyone is nice enough to go through this PLEASE give me some advice this will be my first ever sound saber, iv been planning this for some time to make my own saber and this is it.
Question: will the 4.7ohm 10w resistor work for the rebel star amber led?
Question: will the 220ohm 1/4w resistor work for the 16mm Anti Vandal Latching Amber Ring Switch?
Question: will I be able to media blast and powder coat the Screw on LED blade holder style 13? I have in my cart the style 1 powder coating and the media blasting.
Question: does this saber look good?
Question: will the Acrylic Chassis Disc for PC 2.0 and 18500/18650 pack (Clear) keep the battery resistors and anything else inside from rattling, i ask because this saber will be put through some dueling in the future.
-Im not getting a blade because I already have one (or will have one from vaders vault)
- added the rest of the chassis to my cart put a speaker part inside so i can try to mount the speaker.
Thanks,
FireBlaze97
