Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Luxeon 5 Watt brightness
    I looked everywhere. The employee just was like WTF??? [?][?][?]
    I should just order online...
    "There is no try, only do"
    -Jedi Master Yoda
    Unfourtunatly, unless you get an "old timer" (take no offense please) the employees can tell you about TV's and cell phone plans but know jack $#!^ about CB radios and what is in those mysterious parts drawers.
    I only go to my Radio Shanty first thing in the morning when the manager first opens up, good fella that actually knows the difference between a diode and a resistor[]
    As far as a 6AA holder goes, have no fear cause Underdog is here...
    6 AA Cell Holder with Snap Connection
    Philmore # BH362S
    Dimensions:
    Length: 157 mm
    Width: 32 mm
    Height: 16 mm
    Click here to see our selection of 9V battery snaps used on this battery holder.
    Price: $1.52
    http://minute-man.com/acatalog/AA_Cell_Holders.html
    <center></center>
    I've been running my 5w Green on a 6v setup.. it does light up bright and all, but I have no 3w to compare against in this format. I just ordered a few of those 6 AA holders and I'm thinking of running it with some NiMH 1.2v rechargeables to make 7.2v. We'll see how much better it looks with another volt added. []
    My collection:
    02' MR Anakin AOTC
    05' MR Anakin ROTS
    05' MR Luke ROTJ
    06' MR Maul TPM
    MHS 5w Luxeon (Green)
    5,899
    You'll need to resistor it at that point. 7.2V is above the forward voltage and 6V is not.
    </center>
    ^ But if the max forward voltage is 8.31, wouldn't 7.2v be okay?
    My collection:
    02' MR Anakin AOTC
    05' MR Anakin ROTS
    05' MR Luke ROTJ
    06' MR Maul TPM
    Sith Lord Do-Clo's Avatar
    3,830
    A little not well know fact is that a rechargable battery when fully charged will be higher than what it is rated at. Motorola uses L-ion batteries for some of their portable radios and they have 6 cells at 1.2 volts each for a total of 7.2 volts but when fully charged you will typically see a voltage of about 8.4 volts which could exceed your forward voltage so it would be best to use a resister.
    <center></center>
    i have a question about my 5 watt, i am running it on a 9v (brand new battery) with a 2.2 ohm 5w resistor and it doesn't seem very bright, i am pretty sure my red lux 3 is brighter. any idea what might be wrong?
    Like Do-Clo said fully charged they always are higher then the rated voltage.
    Also, a resistor helps "smooth" it out although you don't have a lot of surges with batteries.
    <center></center>
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by suit_man
    i have a question about my 5 watt, i am running it on a 9v (brand new battery) with a 2.2 ohm 5w resistor and it doesn't seem very bright, i am pretty sure my red lux 3 is brighter. any idea what might be wrong?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
    Check the voltage on the 9v. I'm now using a NiHM 9v and it registers 9.3v on a full charge. Unfortunately I can only fit one 9v in my hilt right now, and because my 9v is only 170mah it doesn't last too long.. but for about 5 minutes the green or royal blue 5w luxeon is extremely bright! I intend on picking up a 250mah or more 9v soon, so hopefully that will help duration until I figure something else out. *I use a 2.7ohm 5w resistor btw.
    My collection:
    02' MR Anakin AOTC
    05' MR Anakin ROTS
    05' MR Luke ROTJ
    06' MR Maul TPM
    MHS 5w Luxeon(RylBl/Grn)
    5,899
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by todd4566
    My collection:
    02' MR Anakin AOTC
    05' MR Anakin ROTS
    05' MR Luke ROTJ
    06' MR Maul TPM
    I was mostly refering to min forward voltages, but yes.
    </center>
