i wonder if there would be room to do a simple led lux in there. i dont know if there would be room, but maybe a thought to consider.
<center></center>
Lan-Ed-Tul
The Brotherhood Of The Sith
Get the rubber boot for it and it won't turn off as easily. you can get a special switch from Tim, which I had him order. If you accidentally touch the button, the blade won't wink out. It's just the opposite of the normal on/off latching switches. If you touch them with the blade on, even if you don't hit it hard enough to unlatch it, it winks out. The only problem I can see with this new switch is if you lean it up against something with the switch off, it could light up. Otherwise this is the best switch for dueling, I've ever seen.
Zhi-don Aquintas
XO RL Sunrider Base
Treasurer/Head Instructor
Lightsaber training OCSWS
Steve I recently sold my obiwan that the guy said was el ready as well. It was the same as he qui gon, I would have had to do some major modding to make it el or led. I gave up on it, I hope you have better luck.
