Page 3 of 13 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 122
Thread: Cheapy Hasbro relay wiring
  1. #21
    Jan 2009
    I am A proud American.
    2,567
    3
    It's the one you recommended...
    Mouser link
    http://mouser.com/ProductDetail/Tyco...yG9AI6JA%3d%3d
    As for you Vos Malek...
    I honestly think that
    1. You took your battery positive and sliced it for the LED positive
    2. you wired it incorrectly (easy to do, the first time I wired it in backwards...)
    I have an accent LED wired directly to the LED and that one flashes a little, But the main one is powered off of the batts.
  2. #22
    Quote Originally Posted by cardcollector View Post
    Oh. Nevermind.
    I've used relays in other setups, but still haven't tried it with the cheap Hasbro boards. I'll give it a go. Thanks.
    There's always a bigger fish.
  3. #23
    I figured it out. I wired it right. I just used a resistor instead of a buckpuck on this one, so I had to splice the negative off the battery pack.
  4. #24
    Youngling
    Dec 2009
    Sunny & Hot Florida
    188
    Here is a new one I just made up
    This should work... I'm going to test it right now.
    EDIT!!!
    It works great.
    I'm rusty with my schematics so bear with me.
    Is there a resistor between the relay and the LED on the positive wire?
  5. #25
    Quote Originally Posted by Dakarn View Post
    Yes, but it can be on either side of the LED (+ or -), and depending on the LED and battery setup, you may not need a resistor at all.
  6. #26
    Youngling
    Dec 2009
    Sunny & Hot Florida
    188
    Quote Originally Posted by Matt Thorn View Post
    Thanks, I'm doing the same setup as cardcollector using the Darth Vader Force Action boards so the schematic is exactly what I was looking for.
  7. #27
    Jedi Initiate vargose's Avatar
    Jul 2008
    St. Louis, MO
    393
    Keep an eye on the relays. I just had to replace one.
  8. #28
    Quote Originally Posted by vargose View Post
    What kind did you use?
  9. #29
    Jan 2009
    2,567
    3
    I broke one of these when soldering to it. They aren''t that sturdy.
    But I mounted mine to the heatsink and I think it is pretty safe.
  10. #30
    If you plan to do some serious action, it would be best to mount the relay to a PCB and affix the PCB inside the hilt.
