Results 1 to 10 of 12
Thread: weathering a powder coated part
    Default weathering a powder coated part
    Just wondering if I were to take a black wrinkle powder coated part and spot sand it for a weathered effect would that compromise the edge of the PC/sanded areas causing it to eventually flake?
    its possible...
    I tend to treat PC as a more durable 'paint'...
    all the same rules apply...IMHO..
    Jedi Master
    FenderBender's Avatar
    Jul 2008
    Earth System - Rhode Island
    1,531
    Depends on the individual PC. Like gloss black, I had to take it to the wire brush on my bench grinder to get it off of a part, even paint stripper would barely touch it. Flat black, can be sanded well, just matte clear over it when you're done weathering.
    GET LATHED!
    eastern57's Avatar
    Mar 2008
    1,958
    High-grit wet-sanding will preserve the surface enough so that it won't fade. It will take you a long to break up the surface to get down to the aluminuim, but you're not "scraping" the finish off... it more of a gradual rub-down... ~1000g or higher
    If you use too high a grit (~400g or less), it digs into the coating too deeply and that will increase fading. It doesn't really "flake" off, but if you leave the surface rough, it'll fade faster.
    while PC 'can' flake in some area.. (usually after a scratch or gouge)..
    if PC in general is 'flaking off'... bring it back and have it re-done.. they didnt a crappy job..
    either cleaning the part before dusting
    not outgassing the part before dusting
    not having a good ground/connection before dusting.
    I've never had issue with the results coming out of the shop here. My intention was to flat black a ribbed/v-groove extension and then take a fairly light grit sand paper to the raised areas for subtle, not intense weathering. It should be fairly safe. Not like spray paint flaking anyway.
    eastern57's Avatar
    Mar 2008
    1,958
    Oh. In that case, it should work fine.
    Does anyone know what happens in more intense conditions like if you strike it with a file to make deep scratches?
    Maybe a good idea is to ask Tim how much he'd charge to have some seconds or scrap stock powdercoated for testing if that would be possible
    eastern57's Avatar
    Mar 2008
    1,958
    Depends on how mad you are... but my guess is that it would scratch.
    Jedi Master Kal El Rah's Avatar
    Jul 2008
    High in the hiltops of the SIMI Valley
    1,378
    Quote Originally Posted by Crystal Chambers View Post
    PC is a baked on polymer/plastic coating, it is very hard, chem resistant and in general 1 of the best innovations of the 20th/21st century, the only flaw is that you can in certain circumstances the possibility to chip/crack the PC or if you will totally chip it off a part, hard to do but it can/has happened. Sanding/wire brushing as stated by Fender can be used to get the weathering effect you are looking for.
    I'M JUST A SPY(LOL)
