Does anyone know which ribbed piece is used for an Obi-Wan style ANH between the choke and main body? Similar to the attached pic?
Are you talking about what was used for the movie prop?
WWI British Rifle Grenade No.3 Mk.1 and top view of "ring" piece
No. 3 Mk.1 with pieces removed and ready to be made into a saber
This info is from: http://www.partsofsw.com
If you want to make an MHS version, then you need this:
http://www.thecustomsabershop.com/MH...oved-P252.aspx
That is the coolest thing I've ever seen. I didn't think it was possible for OBI to be more awesome then he already is but wielding a saber with a grenade attached to it. Wow. Thanks for your help. I will order the ribbed extension with V groove.
Who said anything about a grip? I don't see that anywhere.
It also wasn't a hand grenade, it was launched from a rifle.
And don't forget Obi's saber also had part of a jet engine, part of a camera flash gun, part of a machine gun, part of a faucet handle, and some electronic parts on it. I guess obi was a 'green' Jedi and couldn't pass up the opportunity to recylce.
Yes.
The Parts of Star Wars site hasn't been updated since the part for the emitter and "gear" section have been identified.
They did an awesome Job on every weapon. Each weapon was modified after a currnet weapon of that time.
Prepare for major PWNage.
Definition of n00b- Here.
