Can anyone give me some advice on my Parts list?(Pics below)
Description So Far
- 100% Brass
- 1.5" sink tube
- Entire hilt has atleast a 1" ID, and atleast 1.25" ID X 2" at the pummel.
- Entire hilt is 11"
- Decorated with brass painted pvc, looks like two finishes, worked well.
Goals
- I wanna do this right but could upgrade the buttons, LEDs and charge port later.
- Blade (purple)
- I love the core look with a flare at the base.
- Solid for battle
- Matching accent LEDs or even red and blue. Not sure where to put them.
- I'm interested in ultrasound but I'm open to most cost a effective solution...
- fading light and sound on start up and shut down
- shimmering/humming variation
- clashing sound and light
- Various swings
- and accent LED operation
Shopping List
- Build Your Own Seoul P4 Electronics Kit
- Seoul p4 white
- 4aa battery holder......................................upgrad e to charger port later
- 10 degree lense
- 3.3 ohm 5 watt resister
- SPST MOM switch black button............................upgrade later to gold
- Luxeon III/V Lens Holder
- Luxeon star heat sink
- Corbin Battle blade,30-34"
- Double wrap film?
- 12 color discs...purple/ more red then blue
- Ultrasound 2.5
- Premium speaker
and of course some colored wires, heat shrink, and a few quick releases.
blade holder shouldn't be needed as I have an abs tube with 1"ID 3inches long in the emitter section.
Due to the thicker shroud I will need a longer blade retention screw.
I could build a chassis for soundcard/batterry easily I believe but any suggestions are welcome.
The blade activation switch will be in the center of the grip section. Not sure about power switch...
Any help suggestions or feedback would be awesome!
