Thanks Obi-Dar Ke-Gnomie, I think I saw that one when i was browsing trying to answer my own question
I am planning on building a Royal blue Lux III for my first saber with quick disconnects and a corbin driver (i'm pretty sure that's what it is, forgive me if I sound like an idiot.) I definitely want to stretch a little more once I get the hang of things. I was thinking that once I get her all wired up, I can order a P4 or P5 like xl97 suggested and a filter and try out the brightness to see if im satisfied or want a RGB instead.
Then I realized I might have to re-wire to make sure I feed a P4 or P5 enough juice to run the LED. (on a side note i'm not sure if a Luxeon 3w driver V2 would drive this well, im assuming it will) I would most likely need to up the battery power if anything, but with 4 AA's I think I might be ok. I will have to read more on the Seoul's...
For all you Fraggle fan's out there, sorry for the Wembling there are just so many possiblites...
Thanks again for all the suggestions folks, would you suggest a crystal chamber with an accent LED and RGB for a 2nd time Sabersmith? Or are those types of things you really need practice that a starting saber just cannot give?
