I think the heavier blades are better for spinning and such. They give a better balance, and the added weight really lets you get some speed to the spins.
i will add my two bits, the heavier blades are a bit more difficult to move really fast, but more important is getting a decent balance point. An unbalanced blade is exceptionally cumbersom to wield, for that reason i chopped about 5 inches off of my blade and it has since been much easier to use, and i can swing it quite a bit faster with control. For what that is worth i hope it helps
cheers
I have been using my Force FX saber lately, trying to get used to the waight, but it's to much. I'm a Martial Artest, and I've been training a little on welding swords, and for me the Force FX blades are still to heavey. It's a lot harder to move really fast and spin around. My golf club stick is awesome though, it's so light and doesn't bent, I'm just trying to figure out how to connect it to my hilt and make it detachable. bu it sounds like i'm not going to find a lighted blade thats super light and doesn't bend, but of well...
I took my Ultrasaber to class last night. Basically it's Tim's MHS. I had all my students and instuctors test it out. Then I dueled with it in single combat, circles and line battles. Final evaluation. Its blade heavy with the 40 inch x 1 inch x 1/8 inch walls. A heavier or weighted pommel or other weight in the hilt might make it more stable. It was about the same weight as a standard shinai [bamboo kendo practice sword]but not as well balanced. Ok...I admit it, I'm hooked on the glowing blades. EL was nice, but LED is much superior. It is going to take me some time to get used to the weight difference if I can't weigh the hilt properly. My timing is off, because I am used to the lighter EL. However, now I don't have to worry about whipping and I can lock up with anyone using a shinai without the blade bending. I have already dueled with the lighter, shorter, thinner walled MR blades. Not for me. We have already dented, warped or broken 6 MR sabers. These new LED ones, don't break at all. I took full impact [we never do this in dueling] hits from the strongest members of our class. Nothing...Nada! Impressive....most impressive.
Zhi-don Aquintas
XO RL Sunrider Base
Treasurer/Head Instructor
Lightsaber training OCSWS
Jedi Master
Hmm... I'm thinking of doing a 34" or 36" blade with basic MHS parts, plus the extension piece. Will that work, balance-wise?
Jedi Master
Sweet. I was planning on doing your first hilt exactly (tapered pommel, Extension, hilt tube, and standard blade holder) with a sink tube over it.
I hate to ask, but do you think you could put the 36" in that hilt and test its balance? I normally wouldn't ask, but this is the last thing I need to know before I actually buy my saber.
No problem....
Balance point is about 2 1/2 inches past the emitter tip as opposed to an inch an a half, it's very nice. Now I have to play with it like this for a while and now I am back to thinking of the 35" blade as well hmmmm...
<center></center>
