Results 11 to 20 of 24
Thread: MK3 Flange?
    5,899
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Totaloverride
    Im still debating on how i should mount the blade, i want the flange look but i dont really want those new emitters because everyone is goin to have them. Can anyone help?
    <font color="green">Do or Do Not, There is not try.</font id="green">
    So does anyone with a Obi-wan saber not have an MK3 flange.[] Granted they aren't with blades, but again they just don't work well with electronics.
    </center>
    the only obi ep 4 saber i have is just the belt prop. i started off with a mix of resin and metal parts. now i have replaced all the resin junk with metal parts. so i have a all metal obi ep 4 saber.
    i'll get some pics of it if any want to see it.
    and if you were to make a el version of it, the neck would be closer to size. just a tad bigger, not near as big as one made for led with a 1 inch neck. but those MR obi pics, still look sweet. i think i could forgo the thicker nect in lue of turning into a led convertion.
    The Brotherhood Of The Sith
    I should tell you, the MK3 Flange is not the same part that was used for Luke's saber in ROTJ. A few stunt versions used it, but all the "hero" props were machined.
    Luke's emitter has a flat top, with none of those "holes". It also has a shortt cylindrical piece at the top.
    I'll use the new MHS emitters as examples:
    Obi-Wan:
    Luke:
    These pics aren't exact by any means, but they do illustrate the differences.
    ok well im gettin the part machined but i need the spec on it, anyone got any info.
    yeah, the lukes was a similar style to obi's ep 4 emitter. instead of the ring of holes it had a pipe like protrusion where the blade came out of.
    Im having the machine trades class here at the tech center that i go to machine me the flange for basicly nothing.
    <center><font color="green">Do or Do Not, There is not try.</font id="green"></center>
    <center></center>
    5,899
    Would you still like plans? I have a blueprint of the whole Luke saber that I could dig up.
    </center>
    Sith Lord Do-Clo's Avatar
    3,830
    Xwing if you find the plans send me a copy[]
    Do-Clo
    Brotherhood of the Sith
    Don't make me destroy you...
    5,899
    I uploaded it to my album. These plans have been around for a while.
    http://www.thecustomsabershop.com/ph...orotjplans.jpg
    I could CAD it too so that it's ready to be milled too if you'd like.[]
    </center>
    3,830
    Xwing cad would be nice to have if I get to a point to have one made.
    Thanks
    Do-Clo
