Results 11 to 20 of 24
Thread: Grip material for saber.
    alrighty that will do. Thank you!
    Prepare for major PWNage.
    Definition of n00b- Here.
    Sith Warrior Sairon's Avatar
    Sep 2008
    Calgary, Alberta, Canada!
    1,603
    Order a couple lengths of them because sometimes they are not so sticky and come off.
    is there a certain website that would be practical fr ordering those? I googled it, but no luck.
    Good luck, $K.
    I know the sites are out there, but I haven't found any heatshrink big enough for even a 1 1/4" sinktube saber.
    I'll be watching this thread, too.
    "You don't stop playing because you grow old, you grow old because you stop playing."
    -Benjamin Franklin
    Thanks, Eco. I hope to come up with something good, so I can get look I want.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    You can find large diameter heat shrink here:
    http://www.mcmaster.com/#heat-shrink-tubing/=378x1z
    took a look, couldnt find any self adhesive tubing that will shrink down to the right ID to fit an MHS, the largest shrinks down to 1.2" whereas 1.4" would be more convinient but i reckon that you could get away with it maybe.
    TCSS Resident Annoyance
    NOOBS: Don't be annoying, thats my job, GO HERE
    Sep 2008
    1,603
    McmasterCarr has tubing that shrinks down to fit around a choke, just search around.
    Dec 2005
    Not of this Earth
    6,077
    Quote Originally Posted by galen marek View Post
    Uh, have you ever used heat shrink tubing? You put it onto the part, then shrink it around that part. You don't shrink it first.
    It's not going to shrink any smaller than what you're shrinking it
    around.
    yes, i know but it may cause it to be a bit too tight or thinner than you want it to be
