yea i saw it too and the guy wouldn't even answer my questions.
Master of the Tune
Allright, Corbin gave me the OK to share his info with you guys, I figured best to ask him first. So here it is,
HOW TO MAKE A HASBRO SOUND CARD WORK WITHOUT THAT CHEEZY CLASH FLASHING:
<font color="purple">To run two circuits from the same button, just get a Double Pole
Double Throw button, or a DPDT. It has two isolated circuits attached
to it so you could run the LED driver on one side and the sound module on the other. That's assuming the sound module you're using has a
momentary on/off button and not a latching one. If it has a latching
one, you'd still use a DPDT momentary for the driver, you'd just hook
up a latching relay on the DPDT switch, then connect the sound
module's wires to the relay.</font id="purple">
I'm gonna retrofit my sabers this way. This info came word-for-word from the ever-helpful Corbin Das. Thanks bro!
"Chaka, call off Dawson, will ya?!"
Mi Gin Gonn,
I've tried the diagram for 2 switches I've showed you and it works perfectly. I guess my problem is the reverse of yours. I have one circuit that needs a momentary switch - the sound card - and one that needs a latching switch - the LED running straight off the battery with a resistor. Any suggestions?
Edit: Never mind, the answer was right in front of me, in your post. Now I need to figure out what a latching relay is. Not sure, but doesn't an additional relay use mucho power?
Born of Sith, seduced by the light side.
Hi Guys. Just wanna say I think this is an awasome site and I'm on it a least an hour a day. It's helping heaps of people make their childhood fantasies a reality.
Has anyone seen the soundboards on eBay available from Ultra Sabers ready to install into custom hilts? Was wondering if anyone has tried them and what they think.
Good job fellas
Crikey! I thought he made them himself. I'm from Australia so the range of toy sabers is kinda limited here.
I someone wrote that different models of the Hasbro sabers have better sound and motions sensors and stuff. Are the ones he's selling the better sound boards from the better saber models?
Thanks for your help
Yeah? Awsome.....
The Ultra Sabers guy says you can hook it up to a EL saber without the blinking blade effect. But I suppose you wouldn't have the same problem with the EL as you would with the LED - I think?? (I'm not very good with electronics)
But I might have to get one though.
