What if i want a stunt saber not an led saber
I want to be able to just put a screw in the side of my hilt to be able to hold a dowel in it for rotoscoping...can i accomplish this with MHS built sabers?
Jedi Initiate
Sure. You may need a spacer to fit the dowell in snuggly, but sure.
spacer as in an O ring or something to make the dowel thicker right?
good call
If it's a 3/4" dowel you could just use the 1"-3/4" reducer available in the store as an adapter.
would you recommend just putting one in between the main body and the blade holder?
my bad i guess i didnt realize what a reducer was
i looked it up....good idea
josh, are you just going for a stunt and a stunt only? if so it might be a good idear to grab that reducer, the dowel, and a dremmel tool. grind down the inside most rim of whatever blade holder you choose so the dowel can go further into the hilt. it'll keep the blade from bouncing around so much when it hits something.
also, have you thought about counterweighting you saber? might help for stunt purposes.
that's just my 2 cents. can't wait to see the final product. rock on
