Jedi Initiate
Constant Current circuit
http://www.instructables.com/id/Powe...stant-current/
I am trying to adapt this circuit for our purposes. The only problem with it currently is that the MOSFET get pretty hot at 200ma, after that you have to add a heat sink. Maybe a different MOSFET wouldn't get as hot. Any ideas? Or any other constant current circuits we could use?
Here are some by the same author.
http://www.instructables.com/id/Circ...h-Power-LED_s/
I don't understand why you would want to run a saber constantly? Are you planning to use it in signage?
Jedi Initiate
The current is held constant. So it doesn't drop as the voltage drops. Like a buck puck. Thats what the circuit is for.
I misunderstood...thanks for clearing that up.
Sith Adept
Interesting circuits, I'll have to take a closer look after the weekend. Bit busy right now. They look potentially viable though.
Jedi Initiate
Here are the heat sinks we could use on the mosfet. http://www.mouser.com/Search/Refine....atsink&FS=True
We might be able to use the 1A driver I found instead of the above, more complicated, circuits. http://www.catsemi.com/datasheets/4101.pdf
Sith Minion
why not just use a buckpuck instead of some complicated circuit?
mTm
Jedi Initiate
Because the complicated circuit only costs a few dollars. Very Cheap in comparsion. More effecient than a resistor and not nearly as expensive as a buck puck.
Sith Minion
If you think a $15 is an expensive component, your in the wrong hobby my friend.
