Results 11 to 20 of 27
Thread: How does it Work?
  1. Default
    Yeah, I ha understand tha i Have to use http://www.thecustomsabershop.com/8-...crew--P73.aspx
    But, how could it stay in the Hole made for it?
    To keep it in place, I must use http://www.fasteners-cn.fr/3_nut/3_nut_b.jpg ?
    Am I Right?
    I know i'm a little bit...
    No, when you tighten the screw against the blade it puts pressure on both the blade and the screw and that pressure is what keeps the blade in and the screw from coming out.
  3. Default
    I understand you, I understand the presure systeme but...I keep don't geting how does it keeps the screw of coming out...
    I understand that the pressure keep the blade in place by the screw but, there is nothing, logically who keep the screw itself...I'll try to understand by myself if a buy a Thumbscrew..
  4. Default
    Could someone can show some screens about that, I hope i'll understand better with screens or Video...
    Jan 2009
    I am A proud American.
    2,571
    3
    Ok, here's how it works...
    You buy this- http://www.thecustomsabershop.com/8-...crew--P73.aspx
    To secure this.- http://www.thecustomsabershop.com/LE...-OD--P155.aspx
    You buy a bladeholder like this- http://www.thecustomsabershop.com/Sc...e-1--P183.aspx
    And thread hole in it following this- http://forums.thecustomsabershop.com...ead.php?t=5724
    Then you insert a blade into the bladeholder....
    And screw the thumbscrew into the threaded bladeholder hole. the screw will press up against the blade and WILL NOT COME OUT!!!!
    Want proof???
    http://www.youtube.com/watch?v=2B1C8n4gkFo These guys use the same LED sabers you want to build!
  6. Default
    Thak you for yours explications, but I had already understand that.., what I want to Know it's.....How the screw stay in the Hole ?
    But I think I have understand...Thank you for alls yours explications, I will show you my saber faster as possible...
    Once again, Thank you
    The screw stays in the hole because the hole in the hilt is threaded like the screw, or the hole in a nut. The screw simply screws into the threads in the hilt....then the friction created by pressing the end on the screw up against the blade as you tighten the screw keeps the crew from backing out of the threaded hole.
    The screw has THREADS... the holes it goes into has THREADS.. it screws into and tightens up against the blade in the hole.
    Dec 2005
    Not of this Earth
    6,079
    I think he's not understanding why the screw doesn't fall out, not realizing that the same pressure of the screw that holds the blade against the blade holder also holds in the screw.
    I don't know why he doesn't want to believe us that it does work. I guess he'll just have to try it for himself.
  10. Default
    basically the pushback from the blade creates friction on the threads on the screw and the hilt, the same pressure that locks the blade in also keeps the screw from turning, because of the nature of the screw you can still turn it yourself, but it won't turn on it's own unless something moves it.
