Build your own Luxeon III/Seoul P4 w/
-4AAA battery holder
-Red/Orange
-Collimator Lens 5° viewing angle
-BuckPuck 1000mA 4-wire
-Push on/push off switch with black button
-Luxeon III/V Lens Holder
Screw on LED blade holder style 10
MHS choke style 1 short (when comes back in stock)
7" fluted with standard style switch hole
MPS pommel style 4
MPS insert style 3 (with threaded hole for recharge port)
MPS clip
10/32 x 13/32 black thumb screw (i'm putting the blade retention hole about 1 1/2 cm bellow one of the three gaps in the blade holder, would this be a good screw to use? or something shorter?)
2.1mm power jack/ recharge port
2.1mm plug adapter for smart charger
Where can i get a smart charger or any charger i could use for the recharge port? I have a RC helicopter charger, and im not sure if i could use it, and im not sure if it has a 2.1mm power jack, think it will work? And for wiring the recharge port, do i solder them in the same place as the negative and positive parts of the battery pack? For people who have had experience, whats probably the best AAA rechargeable batteries?
EDIT: Just a quick question i'm curious about. I searched the forums, could not find it, i used the search engine, and could not find it. I've seen tutorials on how to build a saber, and they just put the heatsink, with the LED and everything on it, and how does it not slide further down the hilt, how does it stay in place? Sorry if this has been answered before, i just couldn't find it. Also, can you fight with TCSS's show blade? I'm sure you can so i'm wondering why its called a show blade?
