Results 21 to 30 of 45
Thread: a tip for converting vader to luxeon
  1. #21
    Sith Acolyte DACOTA's Avatar
    Mar 2006
    966
    the thing is i tried it the reverse and no light comes on at all.[]
    "ah general kenobi you are a bold one"-general grievous[xx(]
  2. #22
    Oct 2005
    3,521
    I didnt notice you said you had a different model. I have seen some where the polarity is reversed. Not sure how yours should be hooked up.
  3. #23
    Mar 2006
    966
    can anyone help me with my darth vader 04 model conversion[]
    i have a problem with the led hookup it is soldered but when you plug the blade connector in the sond is grumbly and the led flashes on and off.
  4. #24
    Sith Lord Do-Clo's Avatar
    3,830
    You already know that is is wired incorrectly or it wouldn't act like that. You need a multimeter to check eacy wire to determine if it is positve or negative, use the volts setting to measure it. Sorry that is the best I can do because your board is not in front me.
    Do-Clo
    Brotherhood of the Sith
    Don't make me destroy you...
  5. #25
    Mar 2006
    966
    ONCE I KNOW HOW TO POST PICS I COULD SHOW YOU THANKS DO-CLO[]
    ONCE YOU UNPLUG THE CONNECTOR THE SOUND GOES BACK TO NORMAL.
  6. #26
    you know how to use the edit button, right, dacota?
  7. #27
    Mar 2006
    2,319
    What's with the Caps?
    And what's with the "[" in front of every one of your posts?
    Take a pic, (a good pic) or draw a photoshop wireing diagram of how you have this wired. It will help us brainstorm.
    If you need help posting he pics, there is a pic-posting topic that should help.
    I think you can now load them directly onto this sight, but I have yet to try.
    FAQ
  8. #28
    I don't think it will make a difference, you need to meter the wires to find out what is positive and negative.
    <center></center>
  9. #29
    Mar 2006
    2,319
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by james3
    I don't think it will make a difference, you need to meter the wires to find out what is positive and negative.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
    I just think better if I have something to stare at...[]
    FAQ
  10. #30
    3,830
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by DACOTA
    [ONCE I KNOW HOW TO POST PICS I COULD SHOW YOU THANKS DO-CLO[]
    You can send pictures all day long but without it in front of me I can just guess you must take the time to use a meter and test each individual wire. You must also unwire your current conections and I think you will find that your sound works correctly then. Sorry to tell you this but, THE LED IS WIRED WRONG!
    Do-Clo
