Sith Acolyte
[see i have the seven wires soldered to the poitive and the last wire purple to the negative.i did it the reverse and it did not work. so maybe it could be the clash sensor that is directly plugged to the circuit board.the anakin fx sabers clash sensor is part of the wires that go to the blade and the sensor is inside the stock holder.with the 04 vader the sensor is plugged in to the circuit board.
question for someone with a vader MR 2005.i have a vader MR 02 and i was wondering if the inside diamiter is 1 3/8 of an inch.or if tims holder for the vader 05 would work in the 02.it is gutted nottin in it.goin to put a hasbro sound board in it.using the sound board for somthing else.so i need to know if that will work.thanks
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">but i did take all the colors except purple and attached it to one wire and soltered it to the positive side then i took the purple wire and soltered it to the negative <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Your positives and negatives are backwards.
