Results 1 to 10 of 10
Thread: LED Angle
    Default LED Angle
    I looked first, and unless I over looked it somehow.
    So here it is,
    I was wondering, what angle are some of you using for your LED ?
    5 degree ? 10 degree ?
    or other.
    Sporty
    http://home.insightbb.com/~jedijohns...ome.html-.html
    5,899
    Well, since there is only 5 and 10 available from the store most would be using that. If you mean does anyone have a preferance of one over the other... probably not. The difference is tiny if noticable at all. There is a topic about how they look in the FAQ and Index.[]
    </center>
    Like xwing said, it's kind of a whatever deal. The difference beyween them for what we do is irrelevent. I have used both now and to be frank I can't tell a which one is which set in a hilt with the blade installed, I'm guessing it would be a bigger deal as a flahlight/spotlight situation or if your looking to make an eight foot blade
    <center></center>
    I couldn't tell much of a difference so just went with 10 Degree.
    " I am a Jedi like my Father before me"
    theres not much difference but i use the 10 degree lens
    The Brotherhood Of The Sith
    There is a difference, and it's significant!
    The 10 degree makes for a better flashlight []
    http://www.ultrasabers.com
    Corbin|Strydur|Ultra
    The Holy Luxeon Trinity
    Ultra,
    I know that you also sell sabers, so I didnt know if that is information you share or keep, for keep close at hand due to selling them.
    I have heard that 6 degrees is a good angle to try and achieve. I found recently , maybe on here a comparison of the different angles in the blade.
    Sporty
    I personally like 5 degree.... I'm all for odd numbers, look at the emitter post and see which ones I picked... LOL
    I dunno something about the 5 I like..
    I'm working on making legs for my computer case which is an aspire cube.. But I'm gonna buy some Led's here and Probably a tube and cut them down and put the Led's on the bottom of the case and put the PC over for legs.. We'll see...
    When I figure out why I like the 5 degree better I'll tell ya.. I know my brother seems to think it gets more light down the tube and makes it somewhat more visible in daylight..
    Female Twi'leks are so Hot! I want one. =0)~
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by jedijohnson
    Ultra,
    Sporty
    Corbin has that pic posted, but basically it shows that a 6-10 degree optic is ideal. I prefer the 10 degree because, like I said, it makes a better flashlight.
    i seen that comparison shots and i really couldnt see much difference in them. but most use the 10 so thats what i have been using in mine.
