would a rocker switch work with corbins driver?
just wondering. I found a nice small one at Ace that would fit my hilt perfectly
I am sure it is a latching switch so you would need to use one of corbins drivers that are setup for a latching switch. I will have both the latching and the momentary versions in stock in a few days.
Hmm...i already have the driver. how can you tell the difference?
If you got it here then it is momentary, like Tim said he will get the new ones soon. If you got it elsewhere then it would be a good idea to check with them. On corbin's site you have to specify which one you want and that has just been recentley.
I got it here. So I can only use a momentary switch then?
Sorry, my wiring knowledge consists of RED is the plus sign, BLACK is the subtract sign...[]
With that board yes, you will need a momentary.
Hey no worries you are already doing better then some folks that's why we are all here.
Thats correct especially if you got it recently. One of the earlier version momentarys you could just put a latching switch between the batterys and the driver and use it that way but not with the recent ones.
ok...so for the slow (me) momentary means i have to hold it down for the saber to be on?
I see. That actually works in my favor then, since i salvaged the sound board from my broken Qui-Gon Jinn Hasbro for my LED saber.
Thanks!
