Heiland head piece
OK I've searched and not found....
With the Heiland head piece Tim has, what is the missing piece? the one that fits into the rounded slot on the top. Its on the MR Vader FFX but where can *I* get one?
"Do you know how to use one of these?"
"Yes. The pointy end goes into the other man."
Cool thanks... would've been cool if Tim had them... I'm thinking of ordering it with some other parts but I am not planning on painting it black.. probably a different color.
you meant either one of the 2 parts on top or bottom that the shrouds slots slip around like these:
yeah those... My Vader FFX doesn't have one on the bottom.. is that more the ROTJ look?
Tim doesn't show the bottom...
actually, this is my real heiland converted to a vader. that part come on it when i bought the heiland flash handle off ebay. if you look around on ebay, you might find a handle with that part on it.
and if you look close, the tiny lil pin stickin up is the momentary switch, i use to fire off the hasbro board. nicely blended in so its not noticeable. look like its supposed to be there, although the button is really supposed to be red. not a problem, i can simply get one at Radio Shack, and swap it out.
lol... Whats the furry thing?
It looks like your cat is sitting on the saber waiting for it to hatch.
my cats tail. he walked by while i was tryin to get the pic.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by LAN-ED-TUL
well when i got the convert kit from blasttech, it had that long part. i used it and the handle already had that camel hump lookin part. i used it too. i drilled out the hole where that button was so i could bolt on the small momentary switch i got from radio shack. that large screw head above it is a allen bolt head. u had to use a different size tap cuz at the time, i didnt have one the size of the screw threads that was supposed to go in it. so i improvised.
[img][/img]
