what is the best battery to use
Building my saber and was wondering what type battery to use AA,AAA,or 9 volts
Need help
Albeehotep
with a 4khz inverter the 9v does pretty good. using one of the 8aa or 8aaa holders that wel sell will make it run brighter. Either will fit a 1.5" sink tube. The trick to making the 8aa battery holder fit is you cut off the tabs that stick up to hold the batteries in place and then it fits and works great. If you have a skinnier hilt or are making a short hilt then I would stick with the 9v.
i use two 9 volt to make 18volt in my everyready hilt it makes the saber quite noticeable in daylight and great in the night and it only takes upabout 3 inches of space great if you dont want sound cards
<center>
has anyone else used two inverters with two 9 volts? for my saber, i wired the two inverters up in series. i am not sure if it makes is any brighter than with one inverter. most people wouldn't be able to do this, though. i have a long hilt, but i think that stuff would fit into a graflex if you do it right. what are other people's thoughts about using two inverters for 18v as opposed to one?
two inverters in series??? can you draw a diagram of how you did this because it doesnt make sense that it would work.
if this confuses anybody, let me know. i don't know how easy it is to follow
Ok, that makes my head hurt to even try and figure out what it is doing by hooking it up that way.
it gives you 18v. that is how the guy at coolight.com told me to hook it up so that i get 18v, without the inverter getting hot or anything.
