SPDT switch with Corbin driver and Ultrasound
Could I use the standard push button SPDT momentary switch sold in the TCSS shop to activate and deactivate both a corbin driver [momentary version] and an ultrasound [which is also momentary]?
I know latching corbin drivers are used with latching mr soundboards using the DPDT slide switches. But I'm hoping to use ultrasound which is momentary with a corbin driver [when they are back in stock] which is also available in momentary version for "white flash on clash" with RBW, BBW, and GGW tri-rebels [and full on RRG] and in any event want to use a standard pushbutton switch with the tcss bezel most of my designs require, not the DPDT slider that wont work in most of my designs...can the standard red push button SPDT momentary switch available from TCSS run both mom boards?
