I have a middle section to the MHS and the threads are thrashed, is there a way to sand them down or anything like that so I can get my blade holder attached?
The day may come when the courage of men fails...
...But it is not this day! This day – We FIGHT!
I think the best you can do if the threads are truly 'trashed' is to sand/grind/dremel/whatever the male threads off of your bladeholder and then slip it inside the messed up section. You will then have to drill and tap some screw holes into the (now) untreaded part of the blade holder to put some screws in. The only downside is that it will now become a weak link when dueling with it.
The correct way would be to buy a new middle section and get the good threads back.
If you have a thread die in the same size as the current threads, you can probably use that to repair them, if not...*shrugs*
Red 6 Standing By
thanks for the help I guess it was not as bad as I thought. I cleaned up some spurs stiking out and voila perfect fit
