Ok, got what your goal is. Here's a few quick responses to start this off.
You have a power problem. Your battery is a
7.4v Li-Ion yet
your LED is 17.6v/2 =
8.8v. With a LED setup that requires 8.8v to be fully turned on you are going to need
AT LEAST a 9.6v battery to run that. Otherwise, your saber will either never run at full power, or only for a few short min run at full power. As I've said in other threads, you NEED a battery voltage at least 1v above the required voltage of your LED for the driver circuit (in this case CF) to do it's job.
Now... even if you set up a 9.6v rated battery... that's right at the PEAK of what CF can accept. The max voltage input for CF is 11v and a 9.6v (rated) battery will put out like 12-13v when not connected. That is above the max voltage rating and CF might not like it.
Perhaps we can get Erv' to respond here and say if he thinks it will be ok. I can tell you personally that I fed 13v into my CF one time and it was not happy... It's a risk.
Now next topic is the BuckPuck. I'm not sure what the response time is on a buckpuck, but I don't think they are made to flicker on/off really fast. It needs to be verified... if you hook up a shimmer effect through the buckpuck it might not give you that kind of effect on the output at all. A buckpuck is meant to drive a SET value of current as long as the supply voltage is high enough. It's not a transistor or an analog amplifier...
Next issue is the power extenders. If I understand how Erv' designed those right... they are simply a high power transistor. Meant to take a voltage in, and drive it out the other side but with more force. So... a power extender is meant to accept a low power analog reference voltage on it's input, and drive that similar voltage with more force on it's output. As in... the power extended itself is meant to drive a high current device. But the way you have it wired seems that you want to use a power extender to drive the input of the buckpuck.
Thats kind of like hooking an amplifier up on the end of an amplifier... not what's meant to happen.
Again, I'll read up on the exact design of Erv's power extended and the buckpuck so I can give you a better answer. But that's how I think they are meant to work.
More later, cheers!
