Old ANH luke MR soundboard voltage
I have an old MR ANH luke saber, and it must be one of the old models cos it takes 6 AA batteries, and I read here the newer ones run off 4. does anyone know what voltage they run off?
and I have been told its difficult to hook an EL up to this soundboard setup.. can anyone help with this?
each batt. is 1.5 volt so add it up.
I have not had an older MR to test but it has been said that the sound board runs off of a lower voltage than the blade. The newer MR sabers have three batteries so it is possible that the older sound board runs off of 4.5 volts also.
Do-Clo
Don't make me destroy you...
yeah that makes sense actually, thanks,
aw nuts, i thought he meant the batts. my bad.
With exception to the EL models, all MR sabers run on 4.5 volts, even the 6 cell versions.
http://www.ultrasabers.com
Corbin|Strydur|Ultra
The Holy Luxeon Trinity
Ok thanks ultra, thats what I wanted to make sure of. I think to adapt that to an EL blade I suppose I will need to extend my hilt to accomodate for a new battery setup exclusively for the soundboard.
At the moment thats the only way I can think of to hook it up..
Reaver you can use a 7805 which is a 5 volt voltage regulator to power the sound board without using an additional battery pack.
Do-Clo
I also have an old master anh luke saber.i took it apart for basically everthing inside.i tryed to connect a luxeon lll led to it.everthing worked but the led was very very weak.and i can not figure out why.if the answer is somewhere else I AM SORRY X-WING IF YOU ARE BACK.i looked around but couldnt find an answer so if anyone can help that would be a big help
