I'm simply starting this thread so that I can have a list of what I want/need for my saber. I was having a hard time getting every little part down on a notepad while still being sure it'd all work together, so I hope noone castrates me for this.
This will be a work in progress, and hopefully a build diary as I plan and execute my first lightsaber build, including pictures and all of my mess-ups along the way.
I began riding my first bike on the biggest hill in the neighborhood and this is going to be no different, plus, would anyone really care if i built something easy*?
Now to start.
I'm looking to build 2 Tonfa/Guard Shoto sabers like this:
http://starwars.wikia.com/wiki/Guard_shoto
I'm going to start 'simple' with 1.5' sink tube and corresponding Tee joint.
http://www.lowes.com/lowes/lkn?actio...38K&lpage=none
There are 2 styles of Tee joint that I could find, the one above, and one I'll mention below.
Pros: This has a matching finish to a normal sink tube.
Cons: There's a welded joint on it that's rather ugly and those dimples prevent the sink tube from sliding through it so if I use this I'll have to drill those out leaving ugly holes (cutting the sink tube and putting it on each end can't happen because there isnt enough overlapping for it to be stable imo). On the other hand those holes could be used to house some fun leds or could be an accent color by painting the tube under the joint. Due to one end being already welded on I'd have a hard time making the handle any longer, so hopefully it'll be long enough for my hand. (could possibly use a sink tube to mhs adapter and a pommel to give it some more length.)
The other style I found, that I can't seem to find a picture of is made for a sink tube to screw into all 3 sides of it.
Pros: This would be easier to build with, but would take more sink tubes because it wants threaded ends., but it is a dull color (as in not polished) and has a hammered, stippled type feel (I don't know the name of this but it looks like raw poured metal.) I could fix this by just painting it or something and I've yet to decide which one I'll use.
If anyone happens upon a tee joint for the 1.25'' sink tube I'll scrap this for that because 1.25'' feels more comfortable in my hand, but the general concept will remain the same.
The handle of the saber is going to hold the on/off button and I want the finish to be fancy, and since I won't have any internal size constraints I'm going to go with one of those lit vandal switches. (Hopefully I'll match it to the blade)
http://www.gammods.com.au/store/inde...roducts_id=344
Each one will also have a MRFX Yoda or Vader sound board (as those are the only ones I have 2 of) and I'm leaning twards Yoda just because I like the sounds more. (More than one clash FTW!) 4AA battery pack, Lux III, and a mhs speaker.
I currently have nothing else planned out other than I will be using a sink tube to mhs adapter and a mhs emitter. I am unsure about doing this for both pommels still. I'm also unsure about the blade length and color, but probably not red since Maris' are red.
Just for reference for hilt and blade length: I'm 5'4'', and my measurement from fingertip to shoulder is 26.5 inches. I'll be putting the handle in the middle of the hilt.
*Easy may be relative to each individual user and their experience, results may vary.
