If you are using an UltraSound Board, you would have to make a separated circuit to have that effect on the bargraph. But, if you are using a MRfx board then it is quite simple:
MR boards turn on a full blade in 6 segments(red/orange/yellow/green/blue/purple)
- Hook up the one that lights up the first segment to your 3W LED(dont remember if its red or purple)
- Then hook up the rest of the five wires to the bargraph (in order, 2 segments of the bargraph per wire)
- Remember that the wires are "negatives" and the brown wire is a common positive
You will need 1 resistor for each segment-pair
Be very patient an it will work like a charm!
