08-16-2008, 06:23 PM
#121
08-17-2008, 09:11 AM
#122
these are Simply costume props I made with No electronics But I'm planning on making some working models in the near future. these are My Idea of an ancient Jedi (green one) and Sith (W/claw) lightsabers
[IMG][/IMG]
08-22-2008, 08:17 AM
#123
Youngling
08-23-2008, 05:20 PM
#124
08-24-2008, 07:15 PM
#125
09-03-2008, 01:05 PM
#126
09-06-2008, 02:55 PM
#127
09-08-2008, 05:37 AM
#128
Youngling
09-14-2008, 10:02 PM
#129
My first saber
Okay, I figured I should finally post this.
Hasbro Obi sound card, Luxeon K2 with a BuckPuck (was originally red, but my son didn't like being a Sith), plumbing parts, homemade blade and holder, and blade film and blade ends from TCSS. I built most of this before I discovered TCSS, including getting K2's from Canada, bare stars from Taiwan, heatsinks from New Hampshire, polycarbonate tube from Ohio, hours on a drill press making a blade holder from nylon bushings, and an Obi-Wan Force Unleashed for the sound card from Target. Clearly, I went about this one the wrong way
I wound copper wire into the threads on the drain bezel emitter and used a nylon washer instead of a rubber one for the slip joint.
I used nylon set screws for the blade holder, which glow (as does the nylon slip joint) when the LED is turned on.
The start to my next one that will rely heavily on TCSS internals. It's another sink tube, but trimed to give a Yoda emitter look. I built the clamp from sheet aluminum, a toggle bolt, the edge connector from an old PC sound card, and a steel key (like a Woodruff key, but rectangular).
Reason: detail
09-18-2008, 03:42 PM
#130
